11" R. Beltrame Italian Stiletto Rams-Horn Handles- SS Bayonet grind Blade
new 11" **Beltrame/ Dibon/Folgore** collaboration, "made to order" not a standard production, Genuine Italian automatic Switchblade Stiletto knife made in maniago Italy by Renzo Beltrame/Dibon and Family for **Folgore Knives USA** , hard to find this size/model with Genuine Rams-Horn handles and Bayonet blade, Swivel bolster Stiletto knife measures 11 inches in open position 6 inches closed, sharp Bayonet grind stainless steel blade stamped (stiletto Italy) on front which is Renzo Beltrame's stamp, Polished stainless steel Bolsters button and safety cap , brass liners , solid brass pins secure the Thick Genuine "premium select" Rams-horn handles with Red Dot safety , good kick with solid lockup, everything works as new but has one problem the swivel bolster is hard to press to release blade and sometimes the bolster dont go back into position you have to push it back , back bolster is slightly off center please see pics, swivel bolster may loosen up over time but is defect so being sold at discount for parts or repair. . Hand selected genuine/real Traditional Rams- Horn supplied by Dibon & Centazzo is not typically used on stiletto knives this size, this knife was "made to order " special for **Folgore Knives USA** by *Renzo Beltrame and Familia*, Folgore Knives was part of the assembly team and helped assemble-tweak and professionally polish entire knife. last one i have in 11" with Rams horn and Bayonet blade .
For Sale By: Folgore Knives USA
Item # 128367
Shipping & Handling to United States Addresses: $15.00
Folgore Knives USA has provided the following additional shipping details:
All packages sent with Tracking and adult signature confirmation.
mhbknives
$159.00
mhbknives
$149.00
sharpguy69
$239.00
sharpguy69
Frank B Italian Stiletto 9" Kris Blade, Mother of Pearl
FRANK BELTRAME 9" STILETTO BLOND HORN SCALES DAGGER BLADE MANIAGO ITALY
$159.00
mhbknives
FRANK BELTRAME 9" BEAUTIFUL LIGHT HONEY HORN SCALES BAYONET BLADE ITALIAN STILETTO MANIAGO ITALY
$159.00
mhbknives
FRANK BELTRAME 28CM/11inch BAYONET BLADE BUFFALO HORN AUTOMATIC STILETTO...NEW
$179.00
FRANK BELTRAME 23CM 9" DAGGER STILETTO FRENCH TIP COW HORN...NEW AND SNAPPY!
$169.00
FRANK BELTRAME 23CM 9" DAGGER BLADE STILETTO STAG HORN 4MM KICK SPRING.. NEW AND SNAPPY!!
FRANK BELTRAME 23CM 9" BAYONET AUTOMATIC STILETTO FRENCH COW HORN...NEW AND SNAPPY!
$169.00
OLDER FRANK BELTRAME 28CM/11inch BAYONET BLADE SUPER SELECT BUFFALO HORN STILETTO AUTOMATIC
$190.00
New 13'' Italian Stiletto Brazilian Horn Bayonet Blade by Giovanni Beltrame Maniago Italy 2
FOPT
New 13'' Italian Stiletto Brazilian Horn Bayonet Blade by Giovanni Beltrame Maniago Italy 1
FOPT
New R. Beltrame 13" Italian Stiletto Brazilian-Horn Handles- SS Swedge Blade
Folgore Knives USA
Italian Swivel-Bolster Stiletto with Multi-Tool "Blade" Implement
$169.00
vintage 14cm 5-1/2" Folgore/Dibon classic Stiletto Brazilian horn Picklock
$400.00
Folgore Knives USA
Rare Frank Beltrame company t-shirt - Flli Beltrame F&c 50year anniversary
Folgore Knives USA
FRANK BELTRAME 23CM 9" BAYONET STILETTO STAG HORN 4MM KICK SPRING.. NEW AND SNAPPY!!
$169.00
13'' Picklock Stiletto Swedge Blade Purple Swirl Kirinite TorchFlair Bolster Chad Ruben Custom
$500.00
FOPT
Frank B 9 inch Stiletto Auto Knife with Beautiful Dark Horn Scales Dagger Blade
$179.00
Vantine8665
Item #057- Set of bolsters for 11 inch Frank Beltrame Switchblade for parts or repairs
$38.50
Rubens Blades
Item #023B Salvaged Dark Horn Red Dot Handles for 11 Inch Frank Beltrame Swinguard
$38.50
Rubens Blades
Item #045- Matching Wood handles and bolster for 11 inch Frank B Swinguard
$48.50
Rubens Blades
Item #17 Set of Bolsters for 9 inch Older Frank Beltrame Switchblade
$38.50
Rubens Blades
Item 032-Dagger Blade for 13 inch Frank B Stilletto Parts Repair light stamp
$48.50
Rubens Blades
Item 028-Set of Black Acrylic Handles Matching Bolsters 11 inch Frank Beltrame
$48.50
Rubens Blades
