Shop AAPK Stores by:
AAPK on Facebook
NIB AGA CAMPOLIN 23CM-9INCH ZERO SWAT BLACKOUT G-10 SCALES WITH DAGGER BLADE
Offering a NIB Campolin Zero SWAT BLACKOUT G-10 with a stainless steel BOHLER N690Co BLACKOUT dagger blade and solid AISI 430 bead blasted bolster. There's a double split spring that gives faster action and guarantees longer durability. The inverted Eastern Euro forward plunge lever gives a quick opening action. The stainless steel pocket clip can be easily removed and replaced with a steel shield. This ZERO is a real wicked handfull with the sharpest tip of any production dagger blade around and will no dought be an easy hide in the shadows. See photos for a good description and thanks for looking.
The ZERO is covered by 1 year warranty from the original end user's purchasing date.
Overall length: 22 cm - 8,7"
Blade length: 10cm - 3.94"
Blade thickness: 3.5mm - 0.14"
Weight: 170g - 5.99oz
Blade material: N690Co Stainless Steel
Handle material: G-10
Made in: Italy
Note: You'll always receive the item in the photos. Must be 18 years old to order this item. No international shipping, 48 lower states only. Shared USPS Small Box Priority shipping cost and always ASAP!  $cashapp, Zelle and Money Order will be your choices of payments at checkout.
I buying knife collections...Switchblade, Folder, Flippers, Butterfly, Custom, European, Early American...etc.
Item # 107960
Sale Date: 02/12/2025
Sale Price:  $199.00
Viewed 117 Times
13quot Transitional Blonde Horn
13" Transitional Blonde Horn
CountryBoy77
Edgemaster
Edgemaster
Gorilla Coltelli
