How to cut a nail nick ??
This forum is for posting step by step techniques used in the art of making, customizing, and repairing knives. Please stop by and teach a few things or maybe learn something new from the talented members of AAPK.
2 speed
Re: How to cut a nail nick ??
Postby 2 speed » Wed Feb 04, 2009 2:06 am
FOG wrote:That press is a good idea. Please post some pics id love to see them, and if you can some of the press and the die as well. Thanks,Bryce
I am not a pro knifemaker, just a hobbiest. This is how I do it.
This photo is some nail marks cut with various dremel type wheels. The one on the completed knife is good. The other four are failures and the blades were scrapped.
This photo shows stamped marks. The blank blade is soft steel and shows how the stamp looks before clean up straight from the arbor press. the finished knife has had the mark deepened by hand and is ground, hardened and tempered (of course).
2 speed
Postby 2 speed » Wed Feb 04, 2009 2:32 am
Here is the stamping die. Shop made by me from 1/4" O1 tool steel hardened and tempered to a staw color. Pretty simple to make with the grinder and hand files. One side straight the other a curved tapered radius. The little wheel is what I use to refine the mark after stamping. A 7/8" x 3/32" silicon carbide rubberized abrasive dressed down to a tapered radius.
Here we have the press with the die stamp fixtured in place. The fixture is also shop made. The actual photo shows my tang stamp in the fixture but the nail mark die is done exactly the same way
And since we are talking about shop made tooling I thought I would throw in a photo of this bench block steady. Made with the grinder and files, 3/4" thk x 3" wide x 5" 4140 Cr moly. Very resistant to dings and marring. I set my rivets and punch pins with it laying flat on the bench. When I need to work off the front I chock it up in the jaws of a horizontal vise
hot tempered steel
Postby hot tempered steel » Wed Feb 04, 2009 3:27 am
Pretty cool tool pictures and step by step instructions 2 speed. Thanks.
You can throw your scaps my way if you want. :wink:
jonet143
Postby jonet143 » Wed Feb 04, 2009 3:37 am
i'm gonna move this over to our tutorial forum, don't want to lose this.
johnnie f 1949
FOG
Postby FOG » Wed Feb 04, 2009 6:23 am
2speed, VERY COOL and functional tools.THANKS for posting them. The folding knife you show is AWESOME too !
Thanks for the help.
knifemaker3
Postby knifemaker3 » Wed Feb 04, 2009 1:09 pm
2 speed,
That is cool. I've never seen nor even thought about cutting nail nicks with a press. ::tu::
I do have one question. Is there any deforming of the blade when it's pressed? Does the blade stay good and flat and maintain it's shape?
I will definitely have to try this someday. Looks a whole lot easier than trying to cut nailnicks any other way.
Thanks for sharing!
God Bless!
Craig Blankenship
Booger County Outfitters LLC.
Maker of Custom Knives and Custom Screenprinted Garments
2 speed
Postby 2 speed » Thu Feb 05, 2009 5:00 am
km 3, you are absolutely correct. Stamping the blade that close to the top displaces the metal and leaves a bump on the spine. Found that out the hard way. The way I get around it is;
scribe the layout leaving about 1/4" between the top of the pattern and the edge of the barstock and drill my hole in the tang.
stamp the nail mark.
profile the blank then surface grind.
Works out pretty good as you can see. A 1 ton press would work alot better but the 1/2 ton does a respectable job.
FOG, a jewelry maker friend said that the job could be done with the right graver by hand. It would take some practice but would give better control than a rotary type tool. Just another alternative.
Happy to help
Glenn
orvet
Postby orvet » Fri Feb 06, 2009 7:12 pm
Thanks for sharing your technique!
orvet@comcast.net
Please visit my AAPK store: http://www.allaboutpocketknives.com/kni ... e37-y.html
dburke26
Postby dburke26 » Sat Feb 07, 2009 4:59 pm
Cut the nick before polishing, that way you can polish out the goof ups. Also, you can buy a cheap x/y vice from Harbor Freight, clamp the blade in it, and cut perfect nicks just by cranking the blade into the appropriate tool. Good luck.
mike miller
Postby mike miller » Thu May 21, 2009 1:42 am
Fly cutter with a carbide bit to cut. I have seen them stamped . I also have seen stones on a surface grinder which has been shaped to cut the nail nick. Mike
hangtime
Postby hangtime » Sat Mar 06, 2010 6:40 am
There are tools known as slitting saws used by custom gunsmiths to cut the coccking serrations on the slides of auto pistols. I imagine with the proper set up you could produce a very respectable long pull with one of those.
Never attribute anything to malice that is adequately explained by stupidity. anon.
Elvis
Postby Elvis » Thu Mar 18, 2010 1:45 pm
Wow, this thread had been going on a long time (good info). I like the press idea though. Harbor Freight has a benchtop milling machine that isn't very expensive and using a dovetail bit in it cuts a pretty nice nail nick. Long pulls are even easier. It is a bit time consuming though. A stronger machine (more $$$) wouldn't have to work as hard, but it is accurate and controlable.
Bob
Livin' La Vida Sofa!
Return to “Knife Related Tutorials”
Who is online
Users browsing this forum: No registered users and 6 guests
